5k Compression - Green Bars Visible
Calum Walker
on Feb 25, 2013 at 4:45:20 pm
Hi Guys,
I wondered if anybody could help me, basically I have a number of animations created in Adobe Suite CS6 and C4D R14 with final rendered exports at just over 5k width, 1k high (Sorry I can't give specifics due to project NDA) Square Pixels, 30fps, animation codec, no sound. - This has all gone swimmingly, just a little render intensive!
Now.... the problem...
I am trying to compress these large .mov files in to 30mbps H264 .mov files and have encountered varying issues with a number of compression programmes.
MPEG Streamclip - crashes almost immediately when I try to render.
Quicktime 7 Export - crashes almost immediately when I try to render.
Adobe Media Encoder - cannot encode anything above standard formats typically.
So I tried Episode Pro...
It can encode the video file but leaves a green bar to the right hand side of the encoded file - I can only assume the issue here is that it is above 4k? any robust programmes that people can recommend me testing?
Computer Spec:
Mac OS X 10.6.8
3.2GHz Quad-Core Intel Xeon
16GB Ram
2x1024mb ATI Radeon HD 5770
Software Used:
Adobe Suite CS6
C4D R14
MPEG Streamclip
Episode Pro 6.2.2.9
Sareesh Sudhakaran
Re: 5k Compression - Green Bars Visible
on Feb 26, 2013 at 10:48:40 am
I may be wrong, but the maximum resolution supported by H.264 is 4,096 × 2,304, only in version 5.1 and 5.2.
If it's a multi-panel display the manufacturer either provides hardware or software solutions to get it done.
The only option I know of for 5K is an image sequence. You could wrap this sequence in a container format (MOV, MKV, etc.).
Hope this helps.
Get the Free Comprehensive Guide to Rigging ANY Camera - one guide to rig them all - DSLRs to Reds to the Arri Alexa.
Thomas Alexander
on Feb 26, 2013 at 10:56:22 am
Try Roxio Toast Titanium with the H.264 plugin. It is very stable.
Thomas Alexander | Independent Cinematographer
Soulman Films | Nicosia Cyprus | +357-97697640
Calum Walker
on Feb 26, 2013 at 12:56:15 pm
Thanks Guys for your insight.
Unfortunately toast cannot encode to my native resolution but did manage to encode to 4096 width so is clearly a pretty robust programme.
If anybody else has any ideas please let me know :)
Jeff Greenberg
on Mar 15, 2013 at 12:08:31 pm
Sadly,
It's not possible with these proportions. h.264/mp4 is defined by a Profile and a Level.
There is no Level (right now) that describes beyond 4k, which is why this won't work. You'll have to go to something else for a deliverable.
Best,
Jeff I. Greenberg
Author/Master Instructor/Speaker/Consulting
My contact info and more
