Vertical lines in Compression
Scotty Doesn'tKnow
on Feb 12, 2013 at 6:33:44 pm
I've exported a film shot on a Sony HDR-FX7 at 30 fps. It was exported to a 40g, uncompressed .mov from Final Cut, and I'm very happy with the quality. However, when I go to compress it to create a smaller file (.mp4 for internet, and .m2v for DVD), these vertical lines appear on all edges. Anti-aliasing didn't work - how can I compress and get the video to the quality in which it looks at 40 gigs? I've tried a thousand different compression methods, but none seem to be working...
Thanks in advance!
Sareesh Sudhakaran
Re: Vertical lines in Compression
on Feb 13, 2013 at 11:21:44 am
When you mean edges do you mean the edges of the frame or the objects in the frame? Can you post a screen grab?
Get the Free Comprehensive Guide to Rigging ANY Camera - one guide to rig them all - DSLRs to Reds to the Arri Alexa.
Scotty Doesn'tKnow
on Feb 13, 2013 at 3:50:26 pm
Hi Sareesh,
The edges of the objects in frame. The vertical lines create a 'staircasing' on everything. Again, anti-aliasing didn't work in Compression.
Please see screenshots attached. You'll see the edges - looks even worse with movement.
Screenshots:
http://i1.creativecow.net/u-upload.php#
Sareesh Sudhakaran
on Feb 14, 2013 at 9:56:28 am
The screenshots aren't visible.
Scotty Doesn'tKnow
on Feb 14, 2013 at 3:49:42 pm
Hi Sareesh,
Please click on one of these links:
Then in the upper right corner you'll see two more links titled "screenshot2013..." If you click on each of them, a small screenshot will appear in the window. Click on that window again to make it larger. You'll see the staircasing/vertical lines I'm talking about...
If that doesn't work, is there another way for you to see?
Thanks so much.
Sareesh Sudhakaran
on Feb 14, 2013 at 3:57:42 pm
Doesn't work. It just takes me to a page where I have to upload images. Can you upload it somewhere and share the link?
