Converting different frame rates from h.264 to ProRes
Alex Jones
on Feb 11, 2013 at 7:45:39 pm
Hey guys,
I have a lot of footage from a DSLR and want to edit it so I'm converting to ProRes using MPEG Streamclip. I shot some footage at 24p and some at 60 for slow motion purposes, so I'm wondering if I have to separate the two kinds of footage and convert them separately using different settings (converting the 24p footage with a 24 frame rate, and the 60 with a 60 frame rate in the "frame rate" option box). Or, can I just convert them all at the same time without entering anything in the frame rate box in MPEG streamclip?
Thomas Alexander
Re: Converting different frame rates from h.264 to ProRes
on Feb 26, 2013 at 10:58:59 am
Best way is to leave them as they are and compress them at their original frame rate and than slow the the 60fps in post.
Thomas Alexander | Independent Cinematographer
Soulman Films | Nicosia Cyprus | +357-97697640
