Software suggestions for compressing to 4K mp4
Kevin Cannon
on Feb 7, 2013 at 3:43:22 am
I've received a request for a set of specs that is pretty new to me, and I'm hoping somebody can shed some light on what software might be able to handle converting to this. Some of the specs (like 60Mbps/60Kbps) seem to exceed the available ranges in Compressor. Some of them (like level and profile) don't appear to be selectable in Compressor. Any recommended software or approaches to get these exact specs?
KC
Resolution: 3840x2160
Chroma format: 4:2:0
Sample Depth: 8 bit
Profile: High (HP) CBR
Level: 5.1
Bit rate(VCL): <= 60 Mbps (60 max peak)
#of ref frame: <= 5 frames
Frame rate: <= 30p (TV set to 24Hz)
GOP Size: <= 1 sec
Entropy Coding: CABAC
Audio: 384kbps VBR HE-AACv2 5.1ch @96KHz
Wrapper: MP4
Color Space
Rec709 full range 0-255 8bit
Prehistoric Digital
Jeff Greenberg
Re: Software suggestions for compressing to 4K mp4
on Feb 10, 2013 at 8:32:54 pm
Either Telestrem Episode or Sorenson Squeeze should be able to handle these. Compressor is great, but not optimized for these outputs.
Neither has (I believe) a preset for Profile/level - you need to adhere to what those mean.
Profile is mostly about Color Space
Level is about Size + Data Rate
I'd download both, and go at creating a finished file.
Best,
Jeff I. Greenberg
Author/Master Instructor/Speaker/Consulting
My contact info and more
Kevin Cannon
on Feb 12, 2013 at 3:56:55 am
Thanks Jeff, I'll take a look.
Cheers,
KC
Prehistoric Digital
