MPEG 2 difficulty
Patrice Freymond
MPEG 2 difficulty
on Jan 23, 2013 at 6:06:17 am
I am being asked to compress to these specs:
HD video
Format : MPEG Video
Format version : Version 2
Profile/Level : Main@High
Format Parameters, BVOP : Yes
Format Parameters, Matrix : default
Format_Settings_GOP : M=3, N=12
Bit rate type : Constant
Bit rate : 77,8 Mb/s
Nominal flow : 80,0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Format à l'écran : 16/9
FPS : 25,000 fps
video format : PAL
Resolution : 8 bits
Colorimetry : 4:2:0
Frame Type : Interlaced
Field Order : Top Field First
My problem is that Compressor 4 only allows 40 Mb/s maximum in MPEG 2.
I have a copy of Sorenson so I'll try that but failing that, anybody has a suggestion as to how to achieve such a rate with MPEG 2 and with what software ?
Patrice
Astrid Karlsson
Re: MPEG 2 difficulty
on Jan 24, 2013 at 6:31:17 pm
Hiya,
I'm just passing, but I notice with Adobe Media Encoder CS5.5 (Mac) you can encode an MPEG2 at maximum 80Mb/s
Cheers
~Astrid
MacBookPro 2.2 GHz intel core duo/ 6 GB RAM / GeForce 8600M GT
Mac Pro 2.8 Quad / Nvidia Quadro 4000 / 12 GB RAM / OSX 10.7
Hackintosh 3.41 i7 / AMD Radeon HD 6870 /16 GB 1 / OSX 10.7
Patrice Freymond
on Jan 25, 2013 at 5:59:28 am
Thanks for the info. Turns out Episode can do this too apparently.
Patrice
Patrice Freymond
Editor  Certified Trainer FCP7/X
Post Consultant
Always learning...
Mira Nüesch
on Nov 3, 2014 at 11:13:28 am
Hello Patrice.
I have to make a file with exactly the same settings - could you do with media encoder all those settings? Half of them I don't find to change...
Patrice Freymond
on Nov 3, 2014 at 7:42:59 pm
I am not familiar with media Encoder so can't really help here, sorry
PF
