FLV conversion optimized for Adobe Connect 9
Wis House
on Dec 6, 2012 at 8:39:43 pm
A step-by-step process for converting videos into FLV files for use in Adobe Connect.
STEP 1: Open Adobe Media Encoder
STEP 2: Drag & Drop the video file you want to convert into Adobe Media Encoder.
NOTE: Media Encoder does not handle .MOV files. You may need to transcode into a .mp4 format before doing this.
STEP 3: Select FLV ❘ F4V from the dropdown menu under Format.
STEP 4: Select the Settings... button on the right side of the interface.
STEP 5: The settings window will appear. Click the Format tab in the bottom-right section.
STEP 6: Inside the Format tab, confirm that the circle next to FLV is selected:
STEP 7: Click the Video tab. Confirm that the video settings are as follows:
STEP 8: Click the Audio tab. Confirm that the audio settings are as follows. Click OK.
STEP 9: This will bring you back to the main window. Click on the text under Output File.
STEP 10: This dialogue window will appear. Select where you want your flv video. Click Save.
Step 11: Make sure you have your settings the way you want them and then hit Start Queue in the upper-left corner.
By:
John Lendved, Rob Fontella, & Alan Talaga
The Wisconsin Clearinghouse for Prevention Resources
Check out our video stories at http://www.preventionspeaks.org/stories
Craig Seeman
Re: FLV conversion optimized for Adobe Connect 13
on Dec 11, 2012 at 12:37:28 am
[Wis House] "NOTE: Media Encoder does not handle .MOV files. "
Seriously?
Adobe Connect is at version 9 I believe.
You're showing CS5 for AME whereas current version is CS6.
