Variable bit rate (VBR) output with constant bit rate (CBR) settings?
Shirin Ho
on Nov 28, 2012 at 6:54:26 am
I am trying to transcode a SD clip via compressor. Here's the settings that I would like to achieve.
Video Frame Rate
25 fps
Video Standard
PAL
Video Codec
MPEG-2 Video, Main Profile/Main Level
Audio Codec
MPEG-2 Audio Layer II or
Available audio codec
Container Format
Mpeg-2 Transport Stream (mpg)
Video bit rate
8,000 Kbps, CBR
Audio Bit rate
384 Kbps
Aspect Ratio
16:9
Audio Sample Rate
48KHz
Resolution
1024x576
Scan type
Progressive
However, the only problem I have is transcoding the clip to CBR mode. Even though I have chosen the 'one-pass CBR mode' in Compressor, the output is still VBR mode. Is there any way for Compressor to follow the settings and achieve the CBR mode? Thanks in advance.
Mac OS X (10.6.8)
