Capturing Beta SP for file send
David Patterson
on Sep 2, 2012 at 1:54:47 pm
I am trying to be sent (NTSC) footage from the States which comes from an old 4:3 Beta SP tape.
I have received a few different versions but the results have had poor playback (pixely footage as if were a 1999 internet stream).
I think the problem is that he is sending the footage "uncompressed" at a higher bit rate than what would be used for DVD (does that make sense to you guys or am I spouting nonsense?).
He is using something called Media100 to capture. What settings should he be using to send me a quality file I can use for DVD use (format, codec etc)
Thanks for any help.
David Patterson
Re: Capturing Beta SP for file send
on Sep 3, 2012 at 8:49:08 pm
Just a quick bump - I really apologise - but I'm really stuck for an idea here.
