720P-24p
Mark Dannunzio
720P-24p
on Aug 8, 2012 at 5:31:32 pm
I shot footage using the DVCPROHD 720p-24p format. I set my sequence in FInal Cut Pro properly and now want to compress through Apple's Compressor. My client wants an SD digital format. Any suggestions as to what codec to use? They want to be able to upload it into Kaltura and embed the video into webpage.
Thank you
Mark
Mark Dannunzio
Craig Seeman
Re: 720P-24p
on Aug 8, 2012 at 5:54:02 pm
[Mark Dannunzio] "My client wants an SD digital format. Any suggestions as to what codec to use? They want to be able to upload it into Kaltura and embed the video into webpage."
SD for web delivery only, not a master?
No further compression?
H.264 .mp4 854x480 (16x9 SD square pixel) or 640x360 maybe.
Mark Dannunzio
Re: 720P-24p
on Aug 8, 2012 at 7:07:10 pm
Thanks! Yes, I will compress a master file here. I am thinking the dvcpro720p/24p setting from Compressor for the master encoding?
Mark Dannunzio
Craig Seeman
Re: 720P-24p
on Aug 8, 2012 at 8:43:43 pm
For master just export in timeline codec in FCP7 or ProRes in FCPX
It's possible that if they're on Windows they may not be able to handle DVCProHD .mov so you may decide to just use ProRes (Playback is cross platform).
Ty Thompson
Re: 720P-24p
on Aug 29, 2012 at 3:19:42 am
854 wouldn't work for SD if it's square pixel, 720,400(408) is max for that. Or did you mean anamorphic?
