How to convert m2ts?
brad hebert
on Jul 19, 2012 at 6:54:24 pm
I usually use MPEG Streamclip for conversion, but it doesn't seem to recognize m2ts. What would you recommend?
Eric Strand
Re: How to convert m2ts?
on Jul 19, 2012 at 8:34:22 pm
ClipWrap. http://www.divergentmedia.com/clipwrap/
Lisa Talley
on Aug 1, 2012 at 7:00:58 pm
I had this exact same problem not too long ago and found that if you pull the entire AVCHD metadata folder structure with the .mts file, you should be able to utilize the log and transfer option in FCP7 to convert them to something FCP can handle. I, however, was not given the folder structure and ended up having to throw the whole project in Premiere, learning the program as I went, to make deadline. It handled the .mts files just fine... and turns out, Premiere is an extremely snazzy program.
Lisa Talley
Sacramento Video Production
igor jovcevski
on Oct 6, 2012 at 9:42:10 am
use ffmpeg? it will read almost anything and it will encode in almost everything :)
Igor
Woowave.com
tools for digital artists
