29.97 to 25fps ghosting
Sage Brucia
on Jul 17, 2012 at 12:22:03 am
Hello,
I have some ProRes 1080i 29.97fps footage shot on a Sony A55 DSLR camera, which unfortunately needs to be 25fps.
I've used Compressor 3 to change the frame rate, with Best settings in the Frame Control panel. I'm getting this sort of ghosting effect around the edges of the subject. Here's an example.
http://dl.dropbox.com/u/30619479/ghosting-example.jpg
I'm wondering if I'm doing something wrong, and this can be fixed, or if it's just unavoidable when going down to 25fps?
thanks,
Sage
Jessica Muth
Re: 29.97 to 25fps ghosting
on Jul 25, 2012 at 8:58:01 pm
Honestly, in my experience, there isn't much you can do with it. Since you are removing frames, that may happen. Have you tried in Cinema Tools? They have a reverse telecine option that may be of better use to you.
If I could recommend, a hardware conversion through a Teranex would be the best way to go (but can be costly).
Jessica Muth
Production Operations Manager
Video Labs
Rockville, MD
301-217-0000
jmuth@videolabs.net
Sage Brucia
on Jul 25, 2012 at 9:24:25 pm
I have used Cinema Tools for some of the clips, depending on subject matter. But not using the reverse telecine option. I'll look into it.
Sage
