compress in MOV so it's the lightest possible
Marianne Souliez
on Jul 9, 2012 at 1:50:10 pm
hello,
I have to deliver MOV videos, the longest is one hour, and they are designed for download so they have to be the lightest possible. The image size is fixed (476x268). The soundtrack is just voice.
So far the only parameters that I have adjusted are the compression codec (I chose H264) and the sound (44Hz instead of 48). I know that Compressor, which is the tool I have, has other parameters for the compression, but I have no idea which to tweak to get lighter files.
Can anyone give me a preset that is pretty optimal?
Thanks a lot!
Marianne
Eric Strand
Re: compress in MOV so it's the lightest possible
on Jul 10, 2012 at 2:34:40 pm
You'll want to tweak the data rate. Your video is so small you should be able to lower the data rate to 400-500 kpbs.
