Compressor vs. Cinema Tools Frame Rate Conversion
Jessica Muth
on Jun 23, 2012 at 2:41:20 am
Hi everyone,
I have probably an out-dated question, but I'll ask anyway.
Which do you think is better for a frame rate conversion: Compressor or Cinema Tools? And why?
Let me know what you think! Thanks!
Jessica Muth
Production Operations Manager
Video Labs
Rockville, MD
301-217-0000
jmuth@videolabs.net
Craig Seeman
Re: Compressor vs. Cinema Tools Frame Rate Conversion
on Jun 23, 2012 at 3:55:24 pm
Apples and Oranges. These tools do different things.
Cinema Tools generally changes the flag to change the frame rate.
Compressor generally uses Optical Flow to create new frames.
The serve different purposes.
Jason Brown
on Jun 23, 2012 at 8:53:58 pm
Fcpx conforms frame rates in the timeline on the fly...it's smoother than I've seen before
Craig Seeman
on Jun 23, 2012 at 9:49:09 pm
Absolutely. If you're battling frame rate issues I'd think one is much better served by using FCPX. I'd add that I believe that that may, at least in part, be due to the difference between how Quicktime and AVFoundation work in handling time.
