"One or more targets are incomplete. Each target assigned to a job must have a setting and a destination." (Compressor 4)
Harrison Sim
on Jun 9, 2012 at 3:56:00 pm
I keep getting the error message in the subject when I try to submit a job.
Here's a screen shot of my job:
Not entirely sure what I'm doing wrong.
-Harrison
Brad Elliott
Re: "One or more targets are incomplete. Each target assigned to a job must have a setting and a destination." (Compressor 4)
on Jun 14, 2012 at 9:06:19 pm
The second setting line needs a setting so that an icon appears on the far left side like the top setting. It appears you may have cleared the setting and/or destination on the lower setting.
If you are not trying to create two versions of the the file then delete the second one. If you are trying to create two I would delete the second setting line and start over as Compressor doesn't know what to do as is.
