can't chg Compressor dvd Field Dom setting
Paul Dougherty
on Apr 24, 2012 at 11:20:34 pm
After not using Compressor with an Avid Quicktime (ntsc out) to make a dvd in a while, I ran into strobing / field dominance problem. I had used the default Best Quality 90 min forgetting what a wise man said on Cow "never let compressor figure out the field order" When it dawned on me to set Field Dominance in the Video Format tab to Bottom* - I couldn't do it, it was stuck on Automatic and grayed out. Clicking the little gear icon to the right didn't help. Luckily I stumbled on another older dvd setting where I somehow succeeded in changing Field Dominance to Bottom in the past, used that and problem solved.
Should this kind of thing come up again, what was I doing wrong? Why couldn't I change Field Dominance?
Thanks in advance,
Paul
*copied the default Best Quality 90 and tried to make the change on the copy
Jeff Greenberg
Re: can't chg Compressor dvd Field Dom setting
on May 1, 2012 at 2:22:06 am
You have to have the compressor preset applied to a clip to be able to make changes like that. Just changing the raw preset may not work. Apply, adjust, save and you should be good.
Best,
Jeff I. Greenberg
Editor/Author/Speaker/Consulting
My NAB seminar schedule, contact info and more
