Newb Post Question: Transcoding in FCP X v. Compressor 4
Stephanie Stiavetti
on Apr 24, 2012 at 4:01:23 am
I've discovered the setting in Final Cut Pro X that will let you transcode files to ProRes on import. Are there any pros or cons transcoding directly in FCP X instead of using Compressor 4? What advantages would transcoding in one app have over the other? I've always used Compressor so my instinct is to stay with that, but I want to hear others' thoughts on it.
Stephanie
http://www.theculinarylife.com
Jeff Greenberg
Re: Newb Post Question: Transcoding in FCP X v. Compressor 4
on May 1, 2012 at 2:22:53 am
No real cons - it's using compressor even if you haven't purchased it. It's a headless back end conversion. The disadvantage is your computer is working hard while you try and edit.
Best,
Jeff I. Greenberg
Editor/Author/Speaker/Consulting
My NAB seminar schedule, contact info and more
