Upscaling SD to HD
Bella Gavelin
Upscaling SD to HD
on Apr 11, 2012 at 8:18:18 am
I have DV-PAL footage and want to make it 1920x1080. IS this possible?
bella
Jeff Greenberg
Re: Upscaling SD to HD
on Apr 11, 2012 at 7:24:17 pm
What tools do you have?
What editorial software do you use?
(And you know, all you're doing is blowing it up, right? Yes, the method can make a difference, but it will always be soft)
Best,
Jeff I. Greenberg
Editor/Author/Speaker/Consulting
My NAB seminar schedule, contact info and more
Bella Gavelin
on Apr 12, 2012 at 7:41:02 am
I use FCP7. Have no hardware.
Tried the trial of Red Giant Instant HD yesterday, and I actually thought that compressor did a nicer job. Maybe I was doing it wrong?
I have also heard of avisynth, some real hardcore programming thing. Would this be worth my time learning?
bella
Jeff Greenberg
on Apr 12, 2012 at 12:45:28 pm
If you like the job compressor did, mission accomplished. Make sure you're viewing on a broadcast monitor and not just in FCP - in FCP you want to be looking at 100% (and preferably outputting on a broadcast monitor.)
You really can't judge compressor vs. RedGiant (or anyone else) scaled up...and then scaled back down again for playback in FCP.
Oh, your budget has the ability to use hardware? Forget all this software stuff. Snell and Wilcox converter or a Teranex.
Best,
Jeff I. Greenberg
