Compression for Broadcast
Gale McCraw
on Mar 24, 2012 at 4:09:50 pm
I currently send TV shows to a network as a MPEG-2 Program Stream (mpg) file. They want want me to change the video Codec to mpeg-2 Long GOP 4.2.2P@ML.
After using compressor my file shows GOP 4.2.0. Is there anyway to change this setting? I am using Compressor 3 with FCPStudio.
Any help would be appreciated, Thanks....galearden
Craig Seeman
Re: Compression for Broadcast
on Mar 24, 2012 at 6:55:08 pm
[Gale McCraw] "After using compressor my file shows GOP 4.2.0. Is there anyway to change this setting?"
Try Extras Tab and YUV 4:2:2 Color Encoding checkbox
Normally I use Telestream Episode for this though so I can't say for certain the above works.
Gale McCraw
on Mar 24, 2012 at 8:44:22 pm
Thank you, I will try that. Thanks for your help.
Gale McCraw
on Mar 24, 2012 at 10:25:56 pm
It worked perfectly. Thanks for your help.
Craig Seeman
on Mar 24, 2012 at 10:44:17 pm
You're welcome. Thanks for confirming.
