Encoding an H.264 that's 2765x768
Andrew Saliga
on Mar 5, 2012 at 11:01:56 pm
Attempting to encode an H.264 (preferably in a MOV container) that's 2765x768. I'm having difficulty getting an encoder to accept the res without it either crashing the app or defaulting to a res that's divisible by 16.
I'd prefer to encode with Main Concept or x264 encoder. I've tried FCP, Compressor, Squeeze, DV Kitchen and MPEG StreamClip.
Any ideas or suggestions appreciated.
Andrew Saliga
I/O Specialist/Assistant Editor
Steelehouse Productions
http://www.steelehouse.com
Andrew Saliga
Re: Encoding an H.264 that's 2765x768
on Mar 6, 2012 at 3:02:00 pm
Thanks Sathish. I tried using FFMpegX with no luck. I need to learn to use the command line version.
I didn't realize that After Effects is now licensing the Main Concept H.264 encoder, so I was able to encode to it straight from AE, but in an MP4 container. It only adjusted the resolution by one pixel.
Hopefully I'll hear back from the venue today that that resolution and MP4 container work.
Andrew Saliga
