compressor-jerky
adam dewhirst
compressor-jerky
on Jan 21, 2012 at 12:17:27 pm
i'm basically using compressor to deinterlace for upload to vimeo. the file size only ends up being around 1gb after compressor but i can afford up to 5gb file size. the footage is very jerky at times. i'm wondering if theres anything i can do to improve the quality?
these are my settings in compressor :
Name: vimeo hd encode
Description: No description
File Extension: mov
Estimated file size: unknown
Audio Encoder
AAC, Stereo (L R), 48.000 kHz
Video Encoder
Format: QT
Width: 1280
Height: 720
Pixel aspect ratio: Square
Crop: None
Padding: None
Frame rate: (100% of source)
Frame Controls On:
Retiming: (Best) High quality Motion Compensated
Resize Filter: Statistical Prediction
Deinterlace Filter: Best (Motion Compensated)
Adaptive Details: On
Antialias: 0
Detail Level: 0
Field Output: Progressive
Codec Type: H.264
Multi-pass: On, frame reorder: On
Pixel depth: 24
Spatial quality: 100
Min. Spatial quality: 25
Key frame interval: 30
Temporal quality: 50
Min. temporal quality: 25
Craig Seeman
Re: compressor-jerky
on Jan 21, 2012 at 4:24:02 pm
What's your source frame rate?
Maybe asking the obvious but are you sure your source is interlaced?
You can control the size by controlling the data rate but it's not mission critical in this case although you may be using more of your weekly upload limit than needed.
Are you checking the file before upload or after as there different factors in each case ranging from your computer's playback capabilities to your internet connection.
adam dewhirst
on Jan 21, 2012 at 11:41:06 pm
craig,
thanks for your response. the source frame rate is 25 and i'm sure it is interlaced (shot on fx1).
yes, im checking the file before i upload it. so im not going off the uploaded file.
to be honest, i'm not quite sure what increasing the data rate does but if it adds quality maybe i should try this, although i'm not sure by how much i should increase it. increasing the file size doesn't bother me, as long as its under 5gb and at the moment with the current settings its only 1.16gb.
thanks
adam
Craig Seeman
on Jan 22, 2012 at 1:11:24 am
Are you using Compressor 3.5 or 4?
In 4 use the Video Sharing Services HD 720p Video Sharing preset as is.
Otherwise try this although there are variations.
Video
Frame Rate Current
Key Frames Automatic
Frame Reordering On
Encoding Best Quality Multi-pass
Data Rate Restrict to 10,000 kbits/s
Optimized for Download
Audio
AAC
Stereo
48,000kHz
Quality Best
Encoding Strategy Average Bit Rate
Target Bit Rate 128 kbps
FrameControls On
Output Fields Progressive
Deinterlace Better
Adaptive Details On
Geometry Frame Size 1280x720
I don't see a data rate in your settings. Maybe you have it set very high or to Automatic. Vimeo would still handle it without issue but maybe your computer can't handle playing back the source file.
File size is a duration times data rate.
adam dewhirst
on Jan 22, 2012 at 1:16:40 am
compressor 3.5
thanks craig, i'll try your settings and see if their is an improvement.
adam
