mpeg2 for VOD Delivery with Compressor
Paul Buhl
on Jan 17, 2012 at 2:04:27 am
Hello,
trying to create an SD CableLab spec mgeg2 and have 2 problems.
1. The stream needs to be Transport with embedded audio using Dolby AC3 at 192 kbps (for stereo), and the Transport Stream option in Compressor seems to only make mpeg2 Audio at 384 kbps.
2. The res spec is 528x480 (NOT 720x480) and I can't get an exported file cropped out to this size. The crop tool seems to just crop to 528, then stretch the image back out to 720.
Any thoughts would be greatly appreciated!
Paul.
Jeff Greenberg
Re: mpeg2 for VOD Delivery with Compressor
on Jan 22, 2012 at 6:50:56 pm
Probably can't be done with compressor - you should look at episode for this. Compressor limits quite a bit, what the outputs can be for a number of formats including mpeg2
Best,
Jeff G
Certified Master Trainer | Adobe, Apple, Avid
You should follow me (filmgeek) on twitter. I promise to be nice.
My book (with Richard Harrington and Robbie Carman)- An Editor's Guide to Adobe Premiere Pro
Lynda.com - Compressor Essentials 3.5 and 4
Contact me through my Website
