Mpeg streamclip Batch changing resolution of file
Ergin Kuke
on Nov 11, 2011 at 12:47:07 am
Converting some ProRes movs to H264 for a projection job.
Havent used mpeg stremclip before and it looks great and fast,...only problem, its changing my resolutions by one pixel.
Input file is, say: 700x637. Batch, converts it at 701x637, while if you do NOT go through the Batch window and compress the files individually it stays at the correct res.
Anybody seen this before ?
cheers
PS. Latest OSX version ,...running Lion
(not the beta)
Brad Wright
Re: Mpeg streamclip Batch changing resolution of file
on Nov 17, 2011 at 3:01:21 pm
I would advise dumping MPEGStreamclip and getting Compressor to do the encoding. I've been really happy with the H.264 encoding of Compressor 4. It's able to use all 8 cores of my MacPro. Very efficient and it doesn't have all the bugs of MPEGStreamclip.
Brad Wright is software engineer, so it may be difficult to understand what he is saying. He is always happy to explain his greater detail.
