Cineform Avi to prores?
Sander Lowie
on Oct 17, 2011 at 2:46:13 pm
Hello.
I switched from a PC to a mac a while back. When i worked with my pc I converted some h.264 material from a long running project I'm working on to Avi Cineform Codec because I could not edit with my PC properly. Unforunately I lost my original camera files and I'm now stuck with my Cineform codec files wich are, ofcourse, unusable with a mac.
Is there any way to convert these files back? They can only be played on windows movie maker.
Thank you
Sander
Don Huckleberry
Re: Cineform Avi to prores?
on Nov 6, 2011 at 8:55:41 am
Sorry for the late reply, was poking around and found this msg.
You should be able to use the free NeoPlayer to decode it on Apple:
http://estore.cineform.com/neoplayer.aspx
It's been a couple years since I used it, but it worked well between our macs and win machines. You might have to rename your .avi to .mov - can't remember. Download renameit off of download.com if you need to rename a bunch of files.
Hopefully you already found this.
Don
