Pro Rez Question
Jeff Barringer
Pro Rez Question
on Sep 12, 2011 at 5:56:09 pm
Hello all,
I'm adding a close captioning file to an existing pro rez file - using compressor - pretty straight forward. Except, the resulting pro rez file has a white bar along the bottom and right had side. Yet the image size itself seems to correct. Is there an explanation for this?
Thanks for your thoughts!
Cheers,
Jeff
Mac tower
FCP
All pretty current
Andrew Saliga
Re: Pro Rez Question
on Sep 20, 2011 at 5:02:15 pm
Are you sure you're just not seeing the CC data track?
Andrew Saliga
I/O Specialist/Assistant Editor
Steelehouse Productions
http://www.steelehouse.com
