Avid Sequence to DVD using Compressor
Alex Mermelstein
on Aug 9, 2011 at 3:34:51 pm
I work with Avid DNX files, but very often clients want DVD dailies. From Avid, I export a QT reference movie same as source. I then bring the .mov into a FCP sequence so I can add a slate and B&T. Then, I send the sequence to Compressor (I use compressor because sometimes clients want security burns on the DVD and compressor is great at doing that.)
This encoding process takes about 2 hours for a 60-min reel. My question is what settings can I use to give good quality, but also reduce the encoding time? I currently have it set to One-Pass VBR 6.0-7.0 The original is 1920x1080psf.
Also, if anyone knows a more efficient way, please let me know, but do not suggest Episode. I've tried it and it doesn't let me do things that compressor allows.
Jeff Greenberg
Re: Avid Sequence to DVD using Compressor
on Aug 14, 2011 at 8:53:12 pm
Why aren't you adding slate/B&T inside of Media composer?
You likely could go in at CBR at the same data rate and have a decent looking file.
Last, Compressor is the only tool that will directly make a DVD; Episode and Squeeze can certainly do decent (and possibly better) compression for MPEG2. It's not that Compressor sucks, it's just that their MPEG2 algorithm could be better.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
New- my book (with Richard Harrington and Robbie Carman)- An Editor's Guide to Adobe Premiere Pro
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
