Compressor vs. MPEG Streamclip
Tucker Lucas
on Jul 28, 2011 at 4:25:47 pm
Hey everyone,
We've started using GoPros at work, recording upwards of 4 hours at a time (each file being separated into hour increments by the GoPro).
We've been testing the transcode speed from it's H.264 file to ProRes LT (everything is 720p) in both Compressor and MPEG Streamclip (which is recommended by GoPro). MPEG Streamclip seems to do a much faster job of it.
Would there be any good reason why Compressor wouldn't be able to do the same job as fast as MPEG Streamclip?
Tucker Lucas
Production Manager
Heartland Poker Tour
tucker@heartlandpokertour.com
Craig Seeman
Re: Compressor vs. MPEG Streamclip
on Jul 28, 2011 at 4:41:03 pm
How did you setup your cluster in Compressor?
Tucker Lucas
on Jul 28, 2011 at 5:37:38 pm
I just did one clip at a time. Pulled from the hard drive, not a sequence that was sent to Compressor. Converted to ProResLT, audio disabled.
Tucker Lucas
Production Manager
Craig Seeman
on Jul 28, 2011 at 5:55:43 pm
You'd still want to setup a cluster. It speeds encoding.
Tucker Lucas
on Jul 28, 2011 at 6:11:49 pm
Oh I see. I can tell I have a lot to learn about Compressor. You've pointed me in the right direction to read about it. Thanks!
Tucker Lucas
Production Manager
Ryan Brewer
on Jul 28, 2011 at 6:24:45 pm
Sweet! Been trying to figure this out for a while now!
Ryan Brewer, partner in WarWer Productions, Devon based production firm.
http://warwerproductions.co.uk
