Kbit vs kbit
Jim Wilcox
Kbit vs kbit
on Jul 19, 2011 at 9:52:24 pm
Been asked to provide Constant Bitrate files at 3000 Kbit/s or better for a non broadcast playback system. I am currently confusing myself about Kbit vs kbit Vs Mbit. Can someone point me in the right direction...
Craig Seeman
Re: Kbit vs kbit
on Jul 19, 2011 at 10:05:45 pm
8 bits to a Byte is the basic math.
You might to look at this desktop widget for Mac
http://www.pimley.net/projects/#bitratepro
Jim Wilcox
Re: Kbit vs kbit
on Jul 19, 2011 at 10:19:14 pm
Craig,
I get the basic math its the K vs k that has me questioning myself. If I am setting this up in Compressor I can set kbits/s so I am assuming if they want 3000 Kbits/s I can set up 30000 kbits/s... yes?
Jim Wilcox
Re: Kbit vs kbit
on Jul 19, 2011 at 10:52:13 pm
Craig,
Just want to make sure I am on the right path. Kbit is a decimal expression (1000 bytes) and kbit is binary (1024 bytes) so if they are looking for 3000 Kbits/s I can go 3072 kbit/s... ?
And can anyone weigh in on the non overt nature of Compressor regarding doing CBR h.264 files. Do I set up as Download to not get VBR?
Craig Seeman
Re: Kbit vs kbit
on Jul 19, 2011 at 10:58:24 pm
I see where the issue is now.
binary vs decimal.
The program I linked to uses
KiB for binary and KB for decimal
I believe the assumption is binary for data rates. That's not the case with "sizes."
http://en.wikipedia.org/wiki/Binary_prefix
but look at this too.
http://en.wikipedia.org/wiki/Data_rate_units
Craig Seeman
Re: Kbit vs kbit
on Jul 19, 2011 at 10:53:03 pm
kbits and Kbits are the same.
Kb and KB can be different though. b is bit and B is Byte
