Compressor - Burn Blu-ray with EXISTING H.264 file
Jay Browne
on May 18, 2011 at 2:10:20 am
I frequently create Blu-ray discs of projects for clients using FCP>Compressor. I always have requests for additional Blu-ray copies in the weeks following.
But after waiting nearly 4 hours for a 90 minute ProRes QT master to encode into H.264/AC3 and burn a disc, I would really prefer not to have to go through the encoding process each time a new BD is requested.
After the initial encode batch job with Compressor I have the H.264/AC3 files stored. Is there some way to use Compressor to just burn a one-off by simply using the existing H.264 I have already spent 3 hours encoding?
Does anyone know how to do this?
Jeff Greenberg
Re: Compressor - Burn Blu-ray with EXISTING H.264 file
on May 18, 2011 at 1:30:11 pm
After you've setup compressor, click on the batch (not the individual video clip entry). The Inspector should show "Job Action."
Change your Output Device to Hard drive and you'll get a disk image that you should be able to reuse.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
Jay Browne
on May 18, 2011 at 4:20:46 pm
Thanks for tip! That's a very helpful idea.
Once I have the disk image saved what is the best method to replicate Blu-ray discs from it? I have an external BD burner attached via firewire, and I'm running the FCS suite. Does it require additional software like Encore or Toast?
Jeff Greenberg
on May 18, 2011 at 5:20:19 pm
To be honest, I'm not sure. I figure if it's a disc image, then Apple's disk utility ought to be able to burn it for you. How about you try and let us know. :D
Best,
Jeff G
Peter dewit
on May 19, 2011 at 1:52:01 pm
So you're creating the file then dragging it into a disk image? If that's the case you're probably copying it as data rather than a BD. Typically you'd have to use authoring software of some type(encore Toast etc) to properly build a BD that players will recognize.
Jay Browne
on May 19, 2011 at 3:43:22 pm
So with Toast you can revisit an old project file later and quickly burn a one-off BD disc without re-encoding? I wish there was a way to do that with FCS, it takes an overnight Compressor batch just to create a single disc, unlike DVD Studio Pro where you just open the project and swiftly format a new DVD. Maybe Final Cut X will have some better BD functionality.
Randolf Shanklemeyer
on Aug 18, 2011 at 5:52:46 pm
I am trying the same workflow from compressor. I attempted to burn the BD disk with Toast 10 with the BD Plug-in. I was unable to join the video (H.264 for Blu Ray) AND audio (Dolby Audio.ac3) files. They play as separate files. Any way to join them or suggestions?
Ethan Young
on Jan 6, 2012 at 10:13:03 pm
OK, I have figured out the best workflow for this. After I complete a FCPX project for a client I follow this workflow on my Mac:
1. Export master file from FCPX
2. Use Compressor to encode it for a DVD but choose DISK IMAGE (Hard Drive) in the JOB ACTION>OUTPUT DEVICE setting instead of burning a disc. This creates a disk image (.img) file that I can store to quickly burn extra discs in the future.
3. Use compressor the same way for the Blu-ray version (create disk image)
4. Use Toast 11 to burn the discs. Toast has a feature that allows you to create a disc directly from a disk image.
I find this to be the easiest way to handle additional orders without needing to re-encode or anything.
Ben Gordon
on Nov 8, 2013 at 7:13:27 pm
Hi Ethan, could you possibly elaborate on step 4 in the process you outline - the Toast 11 function to create discs form disk images?
I'm trying to use this to burn consecutive Blu Ray discs and am having trouble finding that Toast feature.
Thanks a million,
Ben
Macbook Pro 2.5 Ghz Intel Core 2 Duo
2 GB 667 MHz DDR2 SDRAM
OSX 10.5.8
Jeff Greenberg
on Nov 8, 2013 at 8:49:00 pm
Change the Destination to Disk Image
Best,
Jeff I. Greenberg
Author/Master Instructor/Speaker/Consulting
My contact info and more
New! Come see me speak @ NAB/Post Production World!
Luke Smith
on Sep 25, 2014 at 1:11:17 am
Howdy. I'm still hoping to find out the answer to the original question. When you use the "Create a Blu-ray" destination in Compressor 4, it encodes the audio and video files, burns the disk, and leaves the encoded sources files behind. In my workflow, I just want to make an adjustment or two to the built-in menu options before I burn the disk again, all without having to re-encode the media files.
I can't help but wonder why it seems like Compressor can't reuse them. Anyone?
Thanks for the help, gents.
Luke
Robert Morgan
on Feb 6, 2018 at 5:40:13 pm
On another forum I saw another approach that seemed to work.
If you still have the batch from your initial DVD burn in your "Completed" tab in Compressor, you can click on the reset arrow in the right hand column of your batch and it will load into the Current tab. When you restart the batch, Compressor recognizes that the coded files are present and will not reprocess them, but rather use them to burn another DVD.
I got this to work when I burned the original DVD from a file rendered from FCPX, such as a Pro-res 422 or other compressed format (rather than sending my FCPS project to Compressor and directly burning from the FCPX project.
However, if I created a DVD by sending my FCPX project to Compressor, and directly making a DVD from FCPX, when I try to reactivate the completed batch, it can't find the source file. I tried sending my project to compressor from FCPX and also reactivating my prior batch, and then copying (dragging and dropping) the video and audio settings from my reactivated batch. Compressor seemed to simply reuse the audio, but reprocessed the video for two-hours.
So now I'm trying to figure out whether there is a way to similarly re-do a burn that came directly from FCPX to Compressor to DVD, by reactivating the completed batch. But so far, no luck.
