Compressor
jesse austino
Compressor
on Apr 28, 2011 at 6:35:08 am
Hey All,
Question, I am using FCP's Compressor for this SD anamorphic job that I just completed with the edit. The final end will be YouTube, I have exported (from FCP) a uncompressed 8bit file of the project and have been attempting compression in Compressor with out any luck at all.
When I bring the file into Compressor it keeps exporting it as 4x3 in stead of 16x9 anamorphic. I know that the original uncompressed 8bit file that is being used is in the correct format (853x480)...
What am I doing wrong???
Thanks for any help.
Jess
Jeff Greenberg
Re: Compressor
on Apr 28, 2011 at 1:43:30 pm
Actually, I'm willing to bet that the original file is 720x480 but being displayed at 853x480.
When you get your video into compressor, go to the geometry tab.
It should detect that the frame size is 720x480 and has a pixel aspect ratio of 1.2
IF NOT, from the drop down for Frame size, choose CUSTOM and change the pixel aspect to NTSC CCIR 601/DV 16:)
Try and and let's find out if it worked!
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
