HSN - 720p/60 to ProRes HQ 1060i/29.97
peter tours
on Apr 22, 2011 at 6:52:33 pm
I have an FCP sequence that is DVCPRO HD 720p/59.94 and HSN's specs are ProRes HQ, Interlaced, 1980x1080, Top Field First, 29.97df.
I have Compressor (latest) and Media Encoder CS5.
How do I get there? I thought ProRes was a "pass thru" codec...?!?!
Thanks for any help.
Peter Tours
TnT Video Services, Inc.
Fort Lauderdale, FL
TRI EA5 1974-1977
Convergence ECS1B 1977-1979
Sony BVE 500 1979 - 1984
Datatron Vanguard 1984 - 1993
GVG VPE141 1993 - 1998
Media 100 1995 - 2006
Final Cut Pro 2005 to infinity and beyond!
Rich Rubasch
Re: HSN - 720p/60 to ProRes HQ 1060i/29.97
on Apr 24, 2011 at 4:47:39 pm
I would export directly out of the FCP timeline and choose ProRes HQ and be sure to check the interlaced box and set it to Upper Field. Then specify the framerate as 29.97.
In the Size checkbox, make it 1920 x 1080. Set Audio to 48k PCM and you should get a perfectly passable clip....a large one, but should pass QC.
Rich Rubasch
Tilt Media Inc.
Video Production, Post, Studio Sound Stage
Founder/President/Editor/Designer/Animator
http://www.tiltmedia.com
peter tours
on Apr 24, 2011 at 5:04:26 pm
Thanks - I wound up watching some tutorials and basically did the same thing you suggest, just in Compressor. I have been spanked before about exporting from FCP compared to Compressor. I chose the uncompressed preset in HD, changed the codec to ProResHQ and did just what you said.
Now I know - I hope someone needs it again before I forget!
Peter Tours
Fort Lauderdale, FL
TRI EA5 1974-1977
