mpeg-2 delivery sepcs
Sean Meredith
on Apr 11, 2011 at 6:08:08 pm
I need to deliver an 80 mbps mpeg-2 (.mpg) file of my film. Doesn't look to be possible in Compressor. Anyone else have to deliver to HD files to Netflix? Other specs in case it helps: codec MPEG-2; profile ID is High Profile; Intra DC Precision is 10 bit; Chroma is 4:2:2; GOP is I-frame only. Audio is supposed to be encoded with 5.1 and the LtRt.
Guessing there are numerous mpeg encoding apps that people use, but I don't want to spend a fortune.
Have to deliver closed captioning too, but luckily they don't have to be embedded. Have to investigate that, too.
Any suggestions or warnings?
sean
Sean Meredith
Director
"Dante's Inferno"
http://www.dantefilm.com
Craig Seeman
Re: mpeg-2 delivery sepcs
on Apr 11, 2011 at 6:54:09 pm
Compressor overs very limited control for MPEG2 Program and Transport Streams.
it sounds like you need Telestream Episode Pro.
http://www.telestream.net/episode/overview.htm
