avi
Core van der Hoeven
avi
on Mar 31, 2011 at 5:55:07 pm
Hello compression goeroe's,
I have a question about converting quicktime H.264 file to a avi .264 file on a mac
Can it be dun in compression, I heard something about compression plugins but I can not find on the internet
the avi must play from usb stick
anyone
regards,
Core
Craig Seeman
Re: avi
on Mar 31, 2011 at 6:17:36 pm
What's the purpose of your workflow?
[Core van der Hoeven] "avi .264"
Is confusing. .264 is not .avi and you can create .264 using Matrox MAX (MXO2 MAX or CompressHD) on the Mac. It's used for Blu-ray.
Do you need H.264 .avi for a specific editing application?
Core van der Hoeven
Re: avi
on Mar 31, 2011 at 6:48:49 pm
thanks for you reply,
I've edit a film in final cut pro, and the client want also a version on a usb stick wich you can directly plug in a led tv and that one must be an avi.
that is the whole story.
Core
Craig Seeman
Re: avi
on Mar 31, 2011 at 7:36:50 pm
I wish I had more technical information. I tend not to trust clients who claim they need "X" if they can provide more specifics. Might the TV also play .mp4 or a transport stream. You'd really need to see the spec sheet for the TV.
That said, MPEG Streamclip can encode H.264 .avi
Core van der Hoeven
Re: avi
on Mar 31, 2011 at 7:46:54 pm
the tv play .mp4 or a transport stream I got the specs
Craig Seeman
Re: avi
on Mar 31, 2011 at 8:01:08 pm
That sounds much better since those are more universally supported.
Oddly Compressor can't create H.264 .mp4 directly (but .m4v extension can be changed. DON'T try that with .mov though). Quicktime Pro can create H.264 .mp4 though.
Also Compressor only seems to create MPEG2 Transport Streams and not H.264. Telestream Episode can though.
