which settings in compressor for MOV-Container, PAL(SD)-resolution, DV-Code
Per Olsson
on Mar 30, 2011 at 8:29:28 am
Hi!
Im going to send a screening copy to a film festival. They want the following format:
MOV-Container, PAL(SD)-resolution, DV-Codec, output field: bottom
first, 48 KHZ, 16 Bit
Right now I got this:
Frame size:
1440x1080
Vid Rate
25 fps
Compressor
HDV1080i50
Pixel Aspect:
HD (1440x1080)
Audio format
16-bit integer
Audio Rate
48 Khz
when I resize the file to get it into SD PAL shall I then use the resize tab (on quicktime settings) and choose:
framesize: 720x576
Pixel Aspect: PAL CCIR601 (16:9)
correct?
which settings shall I use in compressor to get the best quality?
thanks
perik
Jeff Greenberg
Re: which settings in compressor for MOV-Container, PAL(SD)-resolution, DV-Code
on Mar 30, 2011 at 10:57:55 am
[Per Olsson] "which settings shall I use in compressor to get the best quality?
Use the PAL DV preset.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
Michael Nolting
on Oct 11, 2011 at 4:50:47 am
Jeff, I was reading your post looking for an answer similar to this. I have compressor 3.0.5 I need to compress a project on my FCP timeline that is SD to PAL to be used in New Zealand.
I dont see a "DV Preset" in Compressor. I see the following 5 presets:
1. mpeg -4 basic pal for modem streaming
2. mpeg - 4 improved pal for cd
3. mpeg -4 improved pal for east cable streaming
4. mpeg - 4 improved pal large progressive
5. mpeg - 4 improved pal small progressive
I compressed a 1 hour video using preset 1. It produced a 500 meg file, this cant be right! My mpeg -2 files usually create a 3 gig file.
Am I right to set the size to 576 lines in 4:3 format??
The inspector has a lot of other settings that I am not sure of.
Your help greatly appreciated.
Jeff Greenberg
on Oct 11, 2011 at 10:53:06 am
In the settings box of compressor, you should see the following folders:
Apple Devices, DVD, Formats, Other workflows.
If you don't see these 4, something is wrong.
In Other Workflows/Advanced format conversions/Standard Definition
There should be a DV-PAL preset.
Alternately, you should be able to type DV into the search box of the settings window.
Let me know what happens
Best,
Jeff G
New- my book (with Richard Harrington and Robbie Carman)- An Editor's Guide to Adobe Premiere Pro
Michael Nolting
on Oct 12, 2011 at 4:29:15 am
Jeff,
Thanks for the info. I was not sure that compressor would convert video formats as well as compress.
However...................
The process is painfully slow, how slow??
The rate that it went, I was able to calculate that a 2 hour video would keep my MAC busy for over 7 days straight. IMAC with Core I5, 2.5 gig CPU.
This is not acceptable.
There has to be a better way.
Mike
Jeff Greenberg
on Oct 12, 2011 at 11:00:12 am
Mike,
Something else is going on. It certainly shouldn't take that long. At the longest, it should take 2-3x the timeline.
See if Compressor Repair fixes it.
One thought, how are you getting it from FCP to Compressor?
Best,
Jeff G
Michael Nolting
on Oct 12, 2011 at 9:30:29 pm
Jeff,
I am going via "File" --- "Export" ---Export to Compressor, in other words , from the time line, as I do for my NTSC projects which run about 1.25x.
I have received info from another source that it would be very slow.
Mike
