output with .mpg extension?
Ilya Osovets
on Mar 24, 2011 at 10:48:40 pm
Hey everyone,
I need to output a 1280 720 23.98 project to these specs
Video: Mpeg2, 4:2:2, 720 x 486 (recommended) or 720x 480 18 Mbs, 9 frame GOP (Recommended) 29.97 fps. interlaced Video lower field first.
Audio: embedded Mpeg1 layer 2 48Khz 16bit 384 Kbps,
Spot MUST have an .mpg file extension.
I tried somethings in compressor and I can't get it to output with a .mpg extension always goes to .m2v.
Any thoughts?
Craig Seeman
Re: output with .mpg extension?
on Mar 24, 2011 at 11:25:54 pm
You're encoding to m2v is because you're encoding for DVD use.
Duplicate one of those settings.
Or Duplicate Apple>Formats>MPEG2>Program Stream
Under Encoder where it says Stream usage change it from SD DVD to Generic (if you started from a DVD setting).
That would change the extension to mpeg (not mpg though)
in the Extras tab make sure Multiplexed MPEG-1/Layer 2 Audio is checked.
Make sure the Program stream button is selected beneath that.
I'd probably recommend GOP structure IBBP Closed GOP Size 15. You won't be able to select 9 frame GOP structure.
Video Format NTSC Frame Rate 29.97 Bottom First.
I'm probably skipping a few things as you need to make sure you're adding pull down to go from 23.98 to 29.97 and aspect ratio you'd probably want letter boxed.
Telestream Episode is a much better encoder for this type of job and you'll get mpg extension on Program Stream as well.
Ilya Osovets
on Mar 29, 2011 at 2:49:38 pm
Craig,
Thanks for all your help. Your notes have been dead on. Luckily for me the deliverable changed and I was able to deliver at 23.98.
Craig Seeman
on Mar 29, 2011 at 3:37:49 pm
[Ilya Osovets] "Luckily for me the deliverable changed and I was able to deliver at 23.98. "
Short of doing it for broadcast TV, many playback devices will handle 23.98 natively or add the pull down on the fly.
