Changing Pixel Aspect Ratio of existing MPGs?
Scott Bush
on Mar 21, 2011 at 2:29:01 pm
Hi all,
I received several mpeg2 files the other day, to be used as high quality masters for a presentation.
They are supposed to be in PAL format, but instead of a 1.09 PAR they have square pixels.
Does anyone know of any way to change the PAR without re-encoding the file? I have a program (from the Mpeg Append Suite - called Force Anamorphic) that can add an anamorphic flag, to change the PAR on an anamporphic file to the proper widescreen, but these are 4:3. Does anyone know of a similar app to change the PAR from Square pixels to PAL 1.09? Thanks,
Scott
Jason Brown
Re: Changing Pixel Aspect Ratio of existing MPGs?
on Mar 21, 2011 at 3:34:26 pm
I remember a tiny little executable file (PC) that you could run and change header information, like bit-rate, duration, PAR, etc.
I don't remember the name, but I used it to fool DVD players with footage that was over the 9Mbps DVD limit...
I'll take a look tonight at home and see if I still have that application...I used it many many years ago, but I never throw anything good away :)
The file was very small and just changed the header of the file (didn't transcode).
-Jason
Jason Brown
on Mar 22, 2011 at 3:08:58 am
I found it! It's called DVD Patcher...I have the executable file if you want me to send it to you...or you can try to look it up online. I didn't even try a search. Looks like the version I have is v1.06. The modified date was April of 2004, and I haven't used it since way back then.
Also I'm guessing it may be able to re-interpret PAR's of any MPEG...even though its design is for MPEG2 for DVD.
-Jason
Scott Bush
on Mar 22, 2011 at 3:20:57 am
Wow thanks! If you could send it to me that'd be fantastic!
Jason Brown
on Mar 22, 2011 at 10:35:55 am
Email?
Scott Bush
on Mar 22, 2011 at 5:33:20 pm
Right. Thought maybe you had a dropbox link or somethin. :)
please send to DSnutz11 at gmail.com (don't ask but yes for real)
