Rename .mov to .m4v or .mp4 ???
Jeremy Mayhew
on Mar 18, 2011 at 1:25:44 pm
I'm a bit confused about something. I generally compress my videos with the H.264 codec in a .mov wrapper. A client is requesting I use "itunes settings" in MPEG Streamclip, which seems to have the .mp4 or .m4v extension depending on which settings you select in the application. He says it uses the H.264 codec.
I'm wondering if I can merely rename the extension in the finder, from .mov to .m4v or .mp4? It will be playing back from a FAT32 drive to a theater projector.
Craig Seeman
Re: Rename .mov to .m4v or .mp4 ???
on Mar 18, 2011 at 3:37:35 pm
mov can not be renamed to mp4 or m4v.
mp4 and m4v can be interchanged.
mov has a different internal structure though.
Jeff Greenberg
on Mar 19, 2011 at 3:29:09 am
If you encode as an .mp4 or m4v (same thing), you can rename the extension to other things (like .mov and .flv) and the respective players will handle them. It doesn't work in reverse. :(
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
Keith Pratt
on Mar 19, 2011 at 4:18:21 am
Open your H.264 MOV in MPEG Streamclip and click File > Save As > MP4.
Jeremy Mayhew
on Mar 22, 2011 at 7:57:19 pm
Thank you everyone for the clarity!
