Broadcast compression request how to make in Compressor??
Robin lewis
on Feb 16, 2011 at 7:35:51 pm
I need to make a deliverable file and only have compressor, i have been asked for the bellow compressions from the broadcaster but can not match it as much as i try in compressor> For exsample I can not get any Mpeg 2 file to be over 40Mbps but they want 50 Mbps
Can anyone help?
Broadcast Quality
Video Format: MPEG-2 422P@ML 4:2:2
Video Bitrate: 50 mbps I Frame Only
Resolution: 720x608 (we can accept 720x576)
Frame Rate: 25
Rate Control: CBR
Audio Channels: 2Ch Stereo pair
Audio Bitrate: Mpeg 1 layer 2 (we cannot accept uncompressed PCM audio)
Audio Bit Rate: 384 kbps
Audio Sample Rate: 48 kHz
Filed dominance: 1st field / Upper field first.
We require Broadcast Standard 625/50 (PAL) @ 720x608 resolution including VITC on lines 19 & 21.
Review Quality
Video Format: MPEG-2 Main Level @ Main Profile
Video Bitrate: Minimum 5mbps Short GOP (IBBP)
Resolution: 720x576 PAL
Frame Rate: 25
Rate Control: VBR
Audio Bit Rate: 128 kbps
thanks
Craig Seeman
Re: Broadcast compression request how to make in Compressor??
on Feb 16, 2011 at 7:57:47 pm
You're seeing some of the limits of Compressor. Max bitrate of 40Mbps. It can't add VBI either. I also don't think it can do i-Frame only. IP, IBP, IBBP. I don't claim to be a Apple Compressor expert but its limitations are why I use Telestream Episode.
mark luigjes
on Apr 8, 2011 at 1:41:50 pm
Craig, exactly my thoughts :)
Jeff Greenberg
on Feb 23, 2011 at 3:53:16 am
[Robin lewis] "Video Format: MPEG-2 422P@ML 4:2:2
Video Bitrate: 50 mbps I Frame Only"
422 check.
Bitrate 40 (fail)
GOP: IP (fail)
I stopped there.
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com
