4:1 aspect ratio on a dvd?
Maura Cunningham
on Feb 7, 2011 at 2:30:53 pm
Hi all
I have been asked to create a dvd for a banner screen with dimensions of 320x80 pixels. I am working in Final Cut and trying to export through compressor. However, as soon as I choose mpeg2 pal as my file format the dimensions for the frame size in the inspector black out and I cannot change the aspect ratio. Is there a way to do this at all?
Thanks - and heres hoping!
Jason Brown
Re: 4:1 aspect ratio on a dvd?
on Feb 7, 2011 at 3:41:37 pm
The DVD video specification (NTSC) only allows for ONE frame dimension - 720x480. That has EITHER a pixel aspect ratio of .9 (4x3) or 1.2 (16x9).
To accomplish what u need go do...you need to create a seq in fcp that is one of these settings, with black filling in the areas u don't want an image.
This is to make a DVD video, this could also be done using a media player of some kind...
Maura Cunningham
on Feb 7, 2011 at 4:26:58 pm
Thanks Jason. I'm going to try building the clip in a 320x80 sequence then dropping that into a normal 720x576 (I'm in pal world). That should give me the required black that you mention - I hope! Cheers for reply.
Jeff Greenberg
on Feb 8, 2011 at 2:21:52 am
That's exactly what to do.
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com
