PAL MXF File Creation Workflow
Michael Pfost
on Feb 2, 2011 at 6:01:42 am
Hi all --
I need to confirm my workflow of a NTSC video converted into a PAL MXF File (IMX-50 D-10, Op1a, BES Audio) for broadcast in Australia.
1. I captured the video into a ProRes 4:2:2 NTSC file (720x486).
2. I converted the video (in Compressor) to PAL ProRes 4:2:2, 720x576, Upper Field Dominance, 25fps.
3. I then used Episode Pro to convert the PAL ProRes 4:2:2 file into a MXF file (IMX-50 D-10, Op1a, BES Audio).
Does this sound right? I originally used this work flow, but kept the lower field dominance and it was rejected by the network in Australia due to field reversal. I did not realize that they required Upper Field Dominance.
I appreciate any input.
Michael Pfost
Re: PAL MXF File Creation Workflow
on Feb 14, 2011 at 8:53:23 pm
Well -- I didn't receive a response - LOL -- but this workflow is correct. Episode Pro creates perfect MXF files on a Mac.
Craig Seeman
on Feb 14, 2011 at 9:48:35 pm
I'm a heavy Episode user but hadn't tried your specific workflow.
There is a COW Episode forum so posting there might have received a response from someone who had done this.
http://forums.creativecow.net/telestream_episode
Of course some COW hand would bite your head off for double posting but not I.
BTW thanks for posting back because even a self confirmation will be helpful to others who are working through this workflow.
Michael Pfost
on Feb 14, 2011 at 9:58:16 pm
Ahh - I didn't see the specific forum for Episode Pro. Good to know :-)
Thanks for your response as well...
