Distort- Aspect Ratio Math
Lara Johnston
on Jan 24, 2011 at 4:21:49 pm
Hi: I am trying to figure out the math for the various Distort/Scale Values entered when resizing footage of various formats to put into various timelines. I understand where the Scale value comes from (say putting DVCPRO HD 720p60 (960x720) into an NTSC timeline (720 x 480) Scale = 75 = 720x960, expressed as a percentage is 75%. But the distort needed, -50, can anyone explain where that comes from and how that number can be explained mathematically?
I have done a lot of combing through various posts but can't seem to find that information. If I am missing it, can you point me towards the thread?
Lara Johnston
Jeff Greenberg
Re: Distort- Aspect Ratio Math
on Jan 24, 2011 at 4:29:56 pm
Lara,
Basically, it's taking into account for the pixel aspect ratio.
NTSC .9
NTSC widescreen 1.2
DVCPro 720 1.33
Best,
Jeff G
Apple Master Trainer
Avid Cert. Instructor DS/MC
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com
Lara Johnston
on Jan 24, 2011 at 4:43:02 pm
I think I grasp that concept, but what I can't seem to get is why the numbers -12.5, -33 and -50 work in the distort tab of FCP pro.
For example if I cut a DVCPRO HD 720p60 (960x720) clip into an NTSC timeline the aspect ratio requires a distortion of -50 to appear correct (scale at .75 or 75%). How does -50 get derived from the above numbers? Am I missing something?
Lara Johnston
Olin Padilla
on Jan 25, 2011 at 7:37:26 pm
Yeah, this is one of those cases where FCP's sense of logic makes no sense, so I think most of us just avoid manually setting the distort.
It's usually easier to set your resolution manually and 'conform to sequence.'
