mms video squeeze settings
jason zaloga
on Jan 6, 2011 at 8:26:42 pm
video specs are:
Apple Animation, 320 x 240, Millions, 10fps
16-bit Integer (Little Endian), Stereo (L R), 48.000 kHz
data size is 66.90 mb
30 sec duration
i'm using coby rich preset Mobile 3GP Non-SmartPhone 320x240 for squeeze
http://presets.sorensonmedia.com/presets/41-mobile-3gp-non-smartphone-320x2...
the target data rate says 199 kbps but the video keeps coming out 737 kb
need it to be under 300 kbps
i think my settings are fuzzy any help
Craig Seeman
Re: mms video squeeze settings
on Jan 6, 2011 at 10:36:34 pm
http://www.tech-faq.com/mms.html
There are many challenges that exist with MMS:
Adaptation of multimedia content: There may be a difference in the compatibility of multimedia content for different brands of cell phones. If the network operator is supporting your content adaptation – you can enjoy compatibility with more networks and vice versa.
Cell phone configuration: Multimedia Messaging Service requires some parameters to be correctly placed in you handset. Sometimes, due to poor configuration, you may not receive messages.
It depends on the phone and carrier.
Telestream Episode 5.3.2 had many categories of presets
Circuit Switched 3GGP
Circuit Switched 3GGP R5
Circuit Switched 3GGP2
GPRS 3GPP
GPRS 3GPP R5
GPRS 3GPP2
GPRS 3GPP2 EVRC Audio
UMTS 3GPP
UMTS 3GPP R5
UMTS 3GPP2
And each of the above has Download and Streaming subfolders with several presets for each.
That Squeeze preset looks closest to UMTS.
What if you need AMR or EVRC audio instead of AAC for example?
You need to know the target to develop the settings and what works on one phone may not work on another.
jason zaloga
on Jan 7, 2011 at 4:40:13 am
i read the article. so in other words there is no one compression format to view on different networks/phones even though the subscribers have mms?
"You need to know the target to develop the settings" are you referring to the (target) receiving phone or network?
and in that case, is there an explanation of all the mms formats, book,pdf?
Craig Seeman
on Jan 7, 2011 at 4:58:10 am
Smartphones are easier than non smart phones.
Most Smartphones generally can handle H.264 Baseline (some can handle Main) with AAC audio, I believe.
See this 3GP and 3G2
http://en.wikipedia.org/wiki/3GP_and_3G2
AMR Audio
http://en.wikipedia.org/wiki/Adaptive_Multi-Rate_Wideband
This too
http://fileformats.wikia.com/wiki/3GP
jason zaloga
on Jan 7, 2011 at 5:26:43 am
thanks.
