AVI encoding
Edward Wright
AVI encoding
on Nov 17, 2010 at 11:36:09 am
I am trying to encode a quicktime file into an avi for a client.
I am using episode engine to encode. I use it every day to encode to all kinds of formats and it produces perfect results.
For some reason every time I encode the file to avi, it comes out 4:3 and NOT 16:9 (which is what I need it as).
I've changed the settings in episode to make sure that the output file is definitely 16:9, but i still comes out 4:3.
Is this something with avi's or is there something that I am missing?
Rich Rubasch
Re: AVI encoding
on Nov 17, 2010 at 10:41:46 pm
It might be flagged as 16:9 but QT player just doesn't display it. Is it 4:3 squeezed? Then in fact it is 16:9. Or does it cut the sides off and make a 4:3 out of a 16:9?
Rich Rubasch
Tilt Media Inc.
Video Production and Post
Owner/President/Editor/Designer/Animator
http://www.tiltmedia.com
Chris Blair
Re: AVI encoding
on Nov 18, 2010 at 1:03:24 am
Play it on other players like VLC to see how it displays. As Rich points out, Quicktime probably isn't recognizing aspect ratio correctly with the file format.
Chris Blair
Magnetic Image, Inc.
Evansville, IN
http://www.videomi.com
Read our blog http://www.videomi.com/blog
