QT Pro h.264 - jerky interference on panning
Charles Graham
on Nov 9, 2010 at 9:45:32 pm
I have PAL DV footage which I need to be viewed with QT / iMovie on Mac. So I have exported using QT Pro. The settings I used in QT to make the mov (after Google research) were H.264, 2000 kbits/sec, keyframe every 24 frames, 2-pass, 25FPS, tried no deinterface as well as with deinterlace. The size is 768x576 because QT resized to this after the Vegas export - size throughout Vegas process was 720x576.
When I am viewing the mov file in a larger window or full screen (> 6 inch high) there is very noticeable horizontal jerky interference or flicker on panning or zooming. It always appears about one third down from the top of the window/screen.
I have checked the original capture as well as the PAL DV output from Vegas and there is no problem.
Please could someone give me their thoughts.
Charles.
Chris Blair
Re: QT Pro h.264 - jerky interference on panning
on Nov 12, 2010 at 2:40:49 am
Have you tried playing the file on a different media player...like say VLC? It could be a player issue and not a file issue. It would be very odd to encode a file and only see an issue in the playback where you say you're seeing it.
Chris Blair
Magnetic Image, Inc.
Evansville, IN
http://www.videomi.com
Read our blog http://www.videomi.com/blog
Daniel Low
on Nov 14, 2010 at 10:52:22 pm
Don't use QT, use a proper transcoder like Episode or compressor
[Charles Graham] "Re: QT Pro h.264 - jerky interference on panning"
Sent from my iPad Nano.
