Getting Motion Jpeg Compression
Matthew King
on Oct 28, 2010 at 2:19:21 pm
I have a client that needs videos compressed to Motion Jpeg to be shown in movie theatres. I have been able to do this before when I was running Quicktime 7 but now I'm running Quicktime 10.0 on a MAC OS X Version 10.6.4. I know before you were able to go into the System Preferences and enable the legacy encoders for quicktime. But now when I go there, there isn't an option for Quicktime at all.
Is there a way that I can still get the Motion Jpeg codec so I can go into Final Cut Pro or Compressor and pick it as an option?
I would love to use another codec but the theatre only likes JPEG 2000 (which when I export doesn't play smoothly) and Motion Jpeg.
Any help or suggestions would be most helpful. Thanks!
Daniel Low
Re: Getting Motion Jpeg Compression
on Nov 14, 2010 at 11:05:23 pm
Google + QT7 Pro.
Simple.
Sent from my iPad Nano.
Andrew Saliga
on Nov 18, 2010 at 11:00:08 pm
QT7 Pro Should still be on your system. I believe it gets put into the Utilities folder...also I recall an option on the OS update disc to install it.
I hope this helps you a little, but, yes, Google is your friend. :)
Andrew Saliga
I/O Specialist/Assistant Editor
Steelehouse Productions
http://www.steelehouse.com
