Sorenson Squeeze - Extra Frame
Robin Farley
on Oct 21, 2010 at 6:14:51 pm
I'm quite familiar with various compression techniques and software. However, Squeeze is driving me nuts - it appears to be adding an extra frame to videos I encode to H.264 .mov format.
Has anyone experienced this before? It's only a single frame. I've looked at Sorenson's site - they say the encoding process cannot add frames. Did I hit something? Or is there an issue with the source file? The single frame is crucial b/c I'm encoding for animation.
Also, any suggestions on how to maintain the source color, contrast, and gamma for H.264 without messing with filters?
Any thoughts would be much appreciated.
- Robin
Andrew Saliga
Re: Sorenson Squeeze - Extra Frame
on Nov 3, 2010 at 4:45:33 pm
I've had this issue as well (except with MPEG-2 encodes), and unfortunately to do not know a solution.
Andrew Saliga
I/O Specialist/Assistant Editor
Steelehouse Productions
http://www.steelehouse.com
