Open Source Blu-ray Encoding
Clint Milner
on Oct 13, 2010 at 3:22:18 pm
I was wondering if there were any new developments with either AVC, VC-1, or MPEG2 encoding.
This link:
http://x264dev.multimedia.cx/archives/328?info=EXLINK
looks interesting, but I'm looking for just encoding and everything I can see here seems to point to an all-in-1 authoring solution.
I currently use the HC Encoder for SD footage and IMHO it out performs my Adobe Media Encoder, Procoder 3 and in some instances our Cinevision encoder. I've read that it can handle video with larger dimentions than the SD spec, but I'm assuming it's MPEG-2. Also, I'm not sure if you can you jack up the bitrate over 9 in HC?
Any insight would be really helpful.
Many thanks,
Clint
Adobe CS4 Master Suite
Vista Ultimate 64 SP1
Intel Core i7 920 @ 3.60GHz
12 GB DDR3 RAM
NVidia Quadro FX 3700
Matrox RT.X2 LE Capture Card
4 TB RAID 5
