Apple compressor - no interface shows
stu aull
on Oct 8, 2010 at 2:25:51 am
Just reloaded my FCS2 - 6.0.5 into my new 12core Mac-
Compressor menu BAR opens up when I open the App but NO layout. I can manually open each window, but can't seem to get it to load a video clip. Before, I could just drag a clip onto the icon and it would open Compressor, all ready to go.
Layouts menu offers nothing that sets up all the windows.
ran a repair program "Compressor Repair" - no joy.
Compressor 3.0.1
FCS2
Snow leopard 10.6.4
14GB ram
apologies if this is incorrect forum! Did not see one for this App.
Stu Aull
Alaska
Andrew Saliga
Re: Apple compressor - no interface shows
on Oct 8, 2010 at 4:40:16 pm
Yeah, I hate Compressor.
Sorry, my suggestion was Compressor Repair. Is your OS up to date, rebooted your computer? :)
Andrew Saliga
I/O Specialist/Assistant Editor
Steelehouse Productions
http://www.steelehouse.com
Jon Chappell
on Oct 8, 2010 at 5:40:47 pm
Have you tried going to ~/Library/Application Support/Compressor/Layouts and deleting the file Compressor.saved.moduleLayout? It's worth a try.
Let me know if it works for you and I'll add it to the next version of Compressor Repair.
My software:
FCS Maintenance Pack - Tools to keep Final Cut Studio running smoothly and fix problems when they arise
FCP Versioner - Backs up Final Cut Pro projects to XML and creates changelists for each revision
More tools...
stu aull
on Oct 8, 2010 at 7:25:26 pm
Thanks guys-
Tried the Compressor Repair app - no joy
Tried dumping the Layout file - no joy
Reloaded Compressor off install disc-
Its Up!
so - fingers crossed, I have at least an interface now :)
Again my thanks for stepping up
regards
Stu Aull
Alaska
stu aull
on Oct 8, 2010 at 10:48:47 pm
Okaaay-
So 1st time I drag in a clip to Compressor, as soon as I select a codec, the program crashes!
tried the Repair App again, no joy.
All this after a fresh install of Compressor ( 3.0.1 plus 3.0.5 update) off the install disc. Man, all these years of using Comp in my G5 tower w no probs, now in the newly-minted 12core its crash-o-rama
any thoughts?
Stu Aull
12core
14Gb Ram
FSC 2
Jon Chappell
on Oct 8, 2010 at 11:28:01 pm
After the 12-cores came out, Apple released an update for Final Cut Pro 7 to address incompatibilities caused by the fact that Final Cut Studio was designed for a maximum of 8 cores. I would assume that this incompatibility remains in Final Cut Pro 6 which has not been updated. It may therefore be necessary to upgrade to FCP 7 ($299) to fix these issues.
My software:
More tools...
stu aull
on Oct 9, 2010 at 7:24:11 am
Hi Jon-
yes, FCS 3 is in the works, since I can't go on like this!
besides, all the core power and not using latest/greatest is sorta silly ;)
Will be looking at your FCP service software too I think.
cheers
Stu Aull
Alaska
