Thin grey dashes after Compressor encode?
Harry Powell
on Oct 5, 2010 at 9:57:37 am
I'm using Compressor 3.0.5 to convert 1080i ProRes (self-contained from FCP) to 720p H.264
I'm getting thin grey dashes at the very edge of the bottom of the image. They vary in appearance (length) and appear intermittently.
These didn't appear with a Frame Controls off encode. They appeared in an encode where I changed Frame Controls to 'better' for Resize Filter and Deinterlace. But maybe this is coincidence?
Any help greatly appreciated as delivery for this project is within a few hours!
Roli Rivelino
Re: Thin grey dashes after Compressor encode?
on Oct 5, 2010 at 1:30:44 pm
Just a guess, but resize it in settings rather than use the filter, I get a lot of similar problems with Compressor filters.
Good luck, hope it's not too late.
aka Newbie Wan Kenewbie. "The young Newbie, is now a Padawon."
System
Mac Pro 2.8Gb quad core
8Gb RAM
1x 320Gb 7200 hardrive
1x 1Tb 7200 hardrive
Nvidia Geforce 8800 512mb Graphics card
1x 1Tb external WD 'My Book' eSata
Equipment
Panasonic AG-HVX 200
Firestore FS-100
Harry Powell
on Oct 5, 2010 at 1:38:51 pm
Thanks! Not sure if there is time .. but what do you mean by 'settings'? Do you mean in Quicktime?
Roli Rivelino
on Oct 5, 2010 at 2:26:15 pm
No I mean the video settings in whatever codec your using, which you access via the inspector window
System
8Gb RAM
Equipment
Firestore FS-100
Harry Powell
on Oct 14, 2010 at 7:22:56 am
Thanks for the suggestion, but cropping didn't make a difference. It still appeared in the H264 file converted from ProRes.
Still keen to find a solution if anyone has any ideas?
The broken thin line (about a pixel or two tall) on the lower edge is very noticeable when viewing 720p footage, actual size, on a 1080 monitor or TV. Particularly during dark scenes.
What could be causing it?
