create 4x3 with Pillars in compressor for H264 1920x1080 output
Danielle Paluscio
on Oct 5, 2010 at 4:44:19 am
I have exported 4x3 video as a qt ref file. I have to provide my client with various formats, one of which is an H264 1920x1080 file with pillars. Is there any way in compressor to do this without going back into FCP and creating a new sequence, rendering and then re-outputting? I have 27 videos to do this for.
dp
Andrew Saliga
Re: create 4x3 with Pillars in compressor for H264 1920x1080 output
on Oct 6, 2010 at 4:58:00 pm
Sure. This will work with a self-contained QT, so I assume it will work with the ref movie.
First, just confirming that you source is 4x3 SD.
If so, in Compressor there are two sections in the Inspector palette to pay attention to. In the "Frame Conrols" tab, click the little gear button and turn the settings to "On". For resizing filter, turn that to "Best" if time isn't an issue, as you will be upconverting these while maintaining aspect ratio.
In the "Geometry" tab, under dimension select "1920x1080" and under "Output Image" in the "Padding" section you want to select "Preserve Source Aspect Ratio".
-Andrew Saliga
Steelehouse Productions
http://www.steelehouse.com
Danielle Paluscio
on Oct 7, 2010 at 5:17:56 am
Thanks Andrew! That worked except for one little thing...there is a thin green line on the left edge of the 4X3 video - its maybe 2 pixels big and the color of green screen. Anything I can do to get rid of that?
Andrew Saliga
on Oct 8, 2010 at 4:25:07 pm
That's odd. Do you not see it on the original source video? It could be some sort of encoding artifact. Could you post a screenshot?
-Andrew Saliga
Danielle Paluscio
on Oct 8, 2010 at 9:22:15 pm
Here you go - hopefully you can see it...Thanks for your help.
Andrew Saliga
on Oct 6, 2010 at 5:03:30 pm
If so, in Compressor there are two sections in the Inspector palette to pay attention to. In the "Frame Conrols" tab, click the little gear button and turn the settings to "On". For resizing filter, turn that to "Best" if time isn't an issue, as you will be upconverting these while maintaining aspect ratio. Since you have 27 vids you may want to shoot for "Better" as you may not see a difference.
In the "Geometry" tab"
-Andrew Saliga
Andrew Saliga
on Oct 6, 2010 at 5:04:24 pm
Sorry, tried to add info about resizing quality and it somehow posted a cache and double posted.
-Andrew Saliga
