h264 QuickTime Pro export vs Compressor
Dean Goldsworthy
on Sep 2, 2010 at 8:09:57 pm
I exported from an HDV source to a 640x360, 1200kbps, .h264 file from Quicktime Pro and the result looks fantastic, but it is slow.
So I tried the same thing in Compressor (same size and data rate) but the text within my video has jagged edges no matter what data rate I try.
What is going on?
I want to take advantage of Qmaster virtual clusters and render quickly.
Thanks for any input you may have.
Daniel Low
Re: h264 QuickTime Pro export vs Compressor
on Sep 2, 2010 at 8:39:47 pm
Impossible to say without you giving more information about what settings you've used. Possibly you've used multi-pass in QT and not in compressor.
BTW. Read the posts at the very top of this forum.
Dean Goldsworthy
on Sep 2, 2010 at 9:12:26 pm
I turned Frame Controls on and set the Resizing quality to best.
I then adjusted the deinterlace to "better" and that has it looking just like the QT export!
